RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 01-02-2007 | 01:34 PM
  #608
Jellyson's Avatar
Jellyson
Default RE: E-FLITE BLADE CP PRO
ORIGINAL: Commander_Bob
when the tail was in the main esc it had a few blade striks...
I'll go change the pitch and remove the gyro... I'll report back
Justin if the tail motor stalled, that is if it stopped turning while under power, while it was plugged into the main esc, it may indeed have damaged the esc. Usually they fail completely but it is possible for it to fail in a way to still give partial power.
I would suggest getting ahold of another 3-in-1 or a separate esc to try. It is very unlikely that your batteries are both bad, especially if you are geting the full voltage on charge.
