RCU Forums - View Single Post - Sizing servos for installation in a cub wing
Old 01-02-2007 | 05:03 PM
Campy's Avatar
Campy
Default RE: Sizing servos for installation in a cub wing
Here is a link to a calculator. It will tell you how many oz of torque you need.
http://www.csd.net/~cgadd/eflight/calcs_servo.htm
If you want small, powerful servos, check out BlueBird servos (up to 57 oz @4.8 volts).
http://www.bphobbies.com
I use the Bluebird servos all the time. The only negative is you want the metal gear servos. The nylon gears don't hold up, especially if pushed.
