ORIGINAL: rcnz
ORIGINAL: 46u
ORIGINAL: rcnz
I just use the HPI Grease...yes this set include shims and everything you need to replace the stock pot-metal gears.
You'll also just need to download the 18SS manual from HPI, its got instructions on how to install the parts into the diff case.
I do not think it comes with the pinion shims and the only way I know to get them is with the spider gear cup set. I use Harley wheel bearing grease.
http://www2.towerhobbies.com/cgi-bin...?&I=LXTB43&P=Z
Sorry...I meant to say it only comes with the larger shims for the casing itself. No pinion shims...I never actually had to shim the pinion on mine anyway...only the casing...
I have both my pinions shimmed. I do all I can to get the most tooth engagement with out bind and still have a little gear lash
