RCU Forums - View Single Post - Failsafe problem
Old 01-03-2007 | 08:08 AM
jordanogrady
Default RE: Failsafe problem
ORIGINAL: ASSOCIATED_DRIVER
Okay, after reading the instructions many times I think I got it.
After setting to brake or neutral position when failsafe is active.
You will now enter low voltage level sensing programming.
Press button once more for setting 1, press again for setting 2. This is what you need because you are using a 5 cell 6 volt rx pack. Then let it time out and exit programming mode.
If you press it again, then low voltage sensing is disabled. (setting 3).
Just watch the indicator lights to make sure you have selected correct setting.
Cheers mate, thats sorted it! But now when I brake, the failsafe kicks in, I hold the brake for a second and the failsafe goes red and operates!! Strange, any ideas?
Jordan
