RCU Forums - View Single Post - Cutting out balsa parts
Old 01-03-2007 | 12:02 PM
Stew99
Default RE: Cutting out balsa parts
If you put masking tape on both sides of the plywood before you make the cut it will reduce the amount of splintering along the edge. The best way to cut thin plywood is to cut it slightly oversize and then sand or carve it to the final shape.
