servo extention leads
Caution, all extensions are not created equal. Buy those with heavy duty wire (22 gauge or larger) and gold plated connectors. The cheaper tinned connectors will sooner or later cause problems. On long leads and heavy duty servos, you need the larger gauge wire to prevent IR drops from causing servo jitter.
