ORIGINAL: rcnz
ORIGINAL: Nitr0-is-Deadly
how does gear atio work?
the stock spur is 52t and the stock cb is 12 right...if i used like a 13/49 what would that do? would it just strip the gears fast?
Stock ratio in the RTR is 13/52....not 2 sure if 13/49 would work...I would recommend going to 15/49 like the 18ss, try that and then work from there
All depends on what engine you are running as there is a thing as over gearing.
The T15 does not have much grunt so keep this in mind on it. I am running 15 CB and 47 spur.
