RCU Forums - View Single Post - Official HPI MT2 Thread
Old 01-03-2007 | 07:13 PM
  #11746
djheptic's Avatar
djheptic
Default RE: Official HPI MT2 Thread
is the clutch bell spinning freely. can you spin it?.
ORIGINAL: arapoda
ORIGINAL: djheptic
you managed to pull them out away from the shaft?. you must be strong as when i had them clutch shoes i couldnt pull mine out (but then again i never tried that hard). how tight are you doing up the screw on the end of the clutch bell. are you using a m5 washer? you might have lost it when the clutch bell broke.
ORIGINAL: arapoda
Okay, djheptic - The clutch shoes look okay, and they are tight. I pulled the shoes away from the central rod and they spring back into place (they are tight). I don't really know what to look for in terms of faults. Nothing looks out of the ordinary, but if the clutch is engaging the clutch bell, then there obviously must be something afoot.
The screw on the end of the clutch bell is tight and the washers are still intact. There are two washers - One goes against inside rim of the gear itself, another within the clutch bell.
