ORIGINAL: Jellyson
ORIGINAL: Jellyson
snip> vibration isolation is critical for performance. It looks to me like your gyro wire is stretched pretty tight and this will transfer vibration to the gyro.
Also you should not use a single piece of thick foam tape all across the bottom, but rather two narrow strips with a space between them. This will give much better vibration isolation. And make sure the case does not touch the servos, you should eliminate that piece of tape there between the gyro and the servos.
<snip
Like this:
Do you mean use the same tape but have two strips of it with a gap between the strips? that what it looks like in you picture...
The gyro came with the foam tape on the bottom... it is a square with a whole in the center and a cut in the side to the whole it's kinda a U shape.
