RE: homelite with big power
To late..
I milled off .020 off the jug. then I took a die grinder and took .020 of the top of the intake port.
and cut out the in side of the manafold and put on a carb off a us 25cc engine
I took a pice of still that is .117 and brased it to the in side of the side cover.. This cover is made of still not plastic.
I took out the key to the fly well and advanced the timing 6 degres. Wich it about the thiknes of the key way. Put lock tite on it and put on the prop hub.
With a 16x8 prop I am running at 9164 rpms. but it has a bad idel. It will vibrate bad.. I take it up about 1/4 and it will smoth right out.. I do not know why it is doing this yet.. could be the carb or the timing or the .020 I took out of the intake.. I do not know. I will have to play with it more. I did not think about the tork on it.. I will have to see what the trust is going to be.
Thanks for your in put.... but if it is not going to work it was fun to do lol........
Paul
