RE: MVVS .91 Instructions
Paul,
These are two different carburettors...
The one on the engine seems to be the excellent #3222 (but discontinued due to high cost (?)) and the separate one is an older #3216, or #3219. For the Diesel you would want the 7 mm choke #3216.
It is not an original MVVS Diesel head button, but probably one made by Bob Davis. The MVVS unit is mostly brass and protudes into the cap between the cooling-fin part of the head, which has a cross-bar compression adjuster.
Contact Bob Davis on the Diesel forum, or on his web site.
The cooling-fin part of the head seems to be OEM MVVS.
