RE: Thin CA and Styrofoam Lining
I have repaired some VERY large foam areas with this stuff and it worked out great. Mind you, I do NOT like to use it as wood filler - I tried it for that when it first hit the market and I didn't like the results. But then one day I needed to do a repair to foam and I thought it might be just the thing to use. It worked GREAT! And I've been using it to repair foam ever since.
