ORIGINAL: Commander_Bob
snip>
Do you mean use the same tape but have two strips of it with a gap between the strips? that what it looks like in you picture...
The gyro came with the foam tape on the bottom... it is a square with a whole in the center and a cut in the side to the whole it's kinda a U shape.
Yep, it looks like they did the right thing on the bottom mounting tape. But did the instructions also say to secure it sideways like in your pic? I'd still suggest removing that bit (between the gyro and the servos) unless the instructions say otherwise. VIbration from the servos, emp from the motor in the servo, just having it secured that way stiffens it up fro the bottom tape so it doesn't isolate as well, etc. The gyro works by vibrating a tiny silicon ring, so extra vibration can be confusing.
And do loosen up those wires, give it a little slack so it can wiggle.
I don't know if this will help the specific problem when you turn the ch.5 knob to the right but it should improve the performace generally.
