RCU Forums - View Single Post - Would you use wire keeper clips?
Old 01-04-2007 | 12:39 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Would you use wire keeper clips?
These work well, BUT they can go on two ways - with the end of the pushrod facing up or down. One way will result in the servo arm holding the keeper in place while the other way will result in the servo arm popping it off.
Which way is which depends on which side of the servo you are connected to.
