RE: RC multihulls?
hi Ernst i didnt mean i would make the deck flat i was still going to keep the rounded shape i realise the curves do a job.maybe ill just use balsa and carry on all the way round after removing the majority of the frames .or i guess i could do a top and bottom half for the main hull.my intention for the floats was to remove most of the frames apart from near the attach points and the centre of the float(halfway) and after strengthening at these points carry on planking till its all done then cover it in glass as normal.i like the idea of not having to join anything if i can.im sure it can be done without changing the shape any.what do you think about this?.im not lazy if it has to be done by making 6 shells i will.im just exploring possibilitys as ive said im not starting till spring.i may yet even decide on a foam build yet using polyester resin and cloth ,i know ill need to protect the foam from the resin but i can get it more easy and cheaper .
