RE: Ground effect on a Bipe
The wheels roll good. I even changed them to a different size, and this did not help. I have checked and changed toe-in and toe-out, etc. I have eliminated any possible problem with the wheels. The hard left turn is the same no matter what I do to the wheels.
Sometimes it’s good to share your problems. I think I can verify if it is ground effect on the bottom wing. The next I fly this beast, during take-off, I will hold in just enough right aileron to cancel the left trim setting. If the rollout is straight all the way to liftoff this will verify the ground effect theory, if not???
Oldbob
