RE: E-FLITE BLADE CP PRO
first of all, make sure your not accidentally moving your collective when giving rudder commands, ie. lowering the throttle stick. do you have the stock tx? the clicks, even though they are not good, will help you determine that. yes, dual tail motor does draw more amps, but shouldn't be so significant as to have a drop in altitude. do you hear the headspeed droping? or is it just drop in altitude?
