RE: E-FLITE BLADE CP PRO
Commander Bob,
You could save some weight on your DD conversion by cutting off the unused bearing/shaft mount, getting rid of the wiring connectors and if the motor is a RXC then get rid of the heat sinks. This would all help with the balance problem you mentioned.
Mark
