RCU Forums - View Single Post - Ground effect on a Bipe
Old 01-04-2007 | 04:53 PM
HighPlains
Default RE: Ground effect on a Bipe
For ground effect to be a cause the lower wing has to be les then 1/2 chord width above the ground, and providing enough lift to fly the model.
Ground effect reduces the induced drag and starts to make a significant impact when the wing is less than 1/2 of the WING SPAN above the surface. Even a Cessna can fly in ground effect.
