I was running my car today to try and tune it, and I had no luck.[:@] so I messed with the high speed needle first. i did some high speed runs the adjusted it by small little turns clockwise to lean it out. i did some more highspeed runs and brought it in again and did the same thing, i though i had got the highspeed needle set right so i went to the low speed. i adjusted it alittle, and kept on doeing that till i felt a difference and it changed nothing at all.[
] when i floor it it still stays at the same rpm for like a few seconds then goes. it takes off really fast but still sounds bad. so anyways i floored it and it did what it usally does then it started cutting out![X(] the wierd thing is that it changed nothing and plenty of blue exhaust is comeing from the pipe and i tried the spit test to see if it was too hot and it barely sizzled away at all! so i thought i was running rich but the stupid thing was still cutting out.[sm=tired.gif]. so i richened it and it still cut out![:@] then if thats not bad enough, the gears wouldn't change. i did a highspeed run getting the rpms pretty high and it never changed gears. i did hear a wierd sound comeing from the trans but thought it was nothing. so then i was still messing with the stupid needles and the car stoped moving, and the rpms just got really high. i looked and found that the clutch bell was no longer touching the gears in the trans. so now i have 2 really bad problems. im gonna clean it off tonight and checkit out and set the gears properly. since im haveing a bad time with the stupid needles, i want to know what the stock setting for the needles are, which are the really rich breakin settings right? so i wanna know those so i can start fresh. any help would be great, if you guys know what going on. thanks
