RCU Forums - View Single Post - Prop rotation direction
Old 01-05-2007 | 03:27 AM
meddyliol
Default Prop rotation direction
Hi,
I have three questions:
1. This is probably a stupid question but as the prop on the EasyStar is rear mounted which should it rotate clockwise or anti-clockwise when looking towards the front of the plane.
2. Does the Permax 400 need extra suppression capacitors to be fitted, (I will be using a Ripmax Xtra Air25 speed controller). I could easily fit two 47nF capacitors but are they necessary?
3. Do I have to use a superglue or can I use a conventional Araldite glue to fit the motor. It seems to me that if a superglue is used it does not leave any room for tiny adjustments. When it's in it's in so to speak.
Sorry if all of this seems a bit garbled.
Cheers
Brian
