Hello!! Yes Sir, this aircraft is still availiable at NITROPLANES!! Here is the link,
http://www.nitroplanes.com/timo12076arf.html copy and paste in your address bar and "wala" there you are. I've had nothin but good reveiws with mine. I'm a seasoned modeler of some years. I would not suggest this model for someone just starting out because the instruction manual is yet to be desired. However the price is rite for this size aircraft. If your a modeler with some experiance in setting up CG and checking all flight controls to make sure there movements are sound then this baby is for you My Friend. I like to stick to scale as much as possiable so I went with a PULL-PULL system for rudder and elevator. I had to design some of the linkage myself useing some info from the Pac-Areo TM instruction manual
http://www.pacaeromodel.com/TigerMoth/TM120manual.pdf . It sounds like your experianced with TM's allready so I'd say go for it. I like engineering, so a model like this is like dessert after dinner. I enjoy being creative and useing my imagination and this model allows me to do just that. TM's are great flyiers and you can hardly go wrong getting one. If you have any more questions be sure to write back and I'll help the best I can. If you would like pics of the inner workings of my model to help you with your I'll post them. "NO PROBLEM"............Happy Flying My Friend
Untill next time
ADIOS........
Dolan ~wingman~ Gallier
Polson R/C Avaition Group
Polson, Montana.
