RCU Forums - View Single Post - What do you have your conversion in???
Old 01-05-2007 | 07:46 AM
  #88
WarbirdMadMan's Avatar
WarbirdMadMan
Default RE: What do you have your conversion in???
Ok, here she is, install completed and ready to run. I'm pretty happy with it. Made up my own carby adaptor out of
aluminium as the carby mounts are lost when cutting the cases up. Decided to put a canister muffler, with header
pipe on it as the fuse is made for this setup. Bought a KS canister and a header pipe kit as they were easily obtained.
Header pipe kit comes with 3 90 deg bends and a couple of straight pieces so you can braze or weld it to almost any shape.
After running it a few times, had to beef up the engine box as it nearly tore it off the firewall. I didn't know whether to
take that as a good sign or bad one. Was it the super engine pull or was it a S%#ty ARF. After beefing up the engine
box I gave it a few more runs and the pull felt very strong. I have a 20 x 10 Bambula wooden prop on it turning @ around
7000. Not too shabby. So I stuck it on my fish scale and she pulled 21lbs. Should fly it very nicely but until I fly it for
real I won't get too excited.
Cheers KMM
ID:	591151   Click image for larger version
ID:	591152   Click image for larger version
ID:	591153   Click image for larger version
ID:	591154   Click image for larger version
