RE: Rafale complete kit from X-tremejets
Hi Jason,
As long as you have positive angle on the stance, there will be no problem with rotating. It will not "leap" in air like some have done with Gripen. I mixed in some canard and it helps. But if you do not know what you are doing leave canard mix for later. CG is spot on and will be a bit nose heavy for advance pilots. I will try edit a video for low res and mail you.
Regards
Morne
