If the problem is only with the igniter on then you should change your glow plug.
Tony
ORIGINAL: chris750
I have secured the fuel tank at the back with foam, and a paddle pop stick behind it to keep it secure. It's in there pretty tight.
Well the original prop is back on it. I assume the prop that came with a RTF should be balanced? Or not? If not, is there any way I can check it without a balance stand?
By the way its not just the vibrations, the RPM is not smooth, its speeding up and slowing down slightly, by its self - once again its mainly only after I remove the glow starter.
