RE: Perry Oscillating Pump Smoke - it's WORKS???
by the looks of the towerhobbies description, this is a mechanically powered pump that uses the vibration from the engine to swing something within it , and makes no mention of any smoke being produced... quite ingenious, i think
if you cut the flow to the pump, it should literally be sucking at vacuum, which i imagine is a lot less harmful than pumping against a dead head... altho the effect is not going to be instantaneous
