RCU Forums - View Single Post - TINY SERVOS - SOOOO CUTE . . .
Old 01-05-2007 | 05:46 PM
rrragmanliam
Default RE: TINY SERVOS - SOOOO CUTE . . .
ORIGINAL: tigerdude426
I really like the Micro Telemaster alot but I think the feather servos would be too small.
Tigerdude,
Actualy if I were building the Mini Telemaster I would think the HS55 servos would be too large. I would use GWS picos or some of the 3-4 gram servos out there, to save weight and room. The HS55's will be fine and perhaps overkill for the planes you have listed in the 1/2A forum. That plane (the Telemaster) will come in at 6-9 oz and is a gental flier. All the planes I've pictured are 2-3 times the weight of the Mini Telemaster and are highly aerobatic/ fast/ highly stressed planes. I have had NO problems with the HS55 servos and these planes have been flown ALOT. No need to worry about those servos,just build. Be sure to revisit the 1/2A forum as you will have many other questions during your build. Engine, Fuel tank, covering materials, hingeing techniques,specific to 1/2A aircraft are a few issues that come to mind. Remember the smaller your plane gets, the more weight is an important issue. Be carefull, when the small bug gets you it's tough to get away
Darren
