RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 01-05-2007 | 09:04 PM
  #805
Jellyson's Avatar
Jellyson
Default RE: E-FLITE BLADE CP PRO
Doh! I knew there was something I was supposed to be doing besides just having fun.
Sorry, I completely spaced it out. All I can say is that it was plenty adequate and I never hit full throttle, either in normal or idle-up.
Certainly greater than 10 feet per second, and I try to get throttle just up to where the headspeed starts to load up in normal mode.
Nowhere near that high throttle in idle-up, it zoomz pretty good, good climb rate, but as I said I wasn't specifically testing, just having fun and concentrating on not crashing (I had a friend with me, didn't want to embarrass myself too much!)
Everything stock except the swash and links, and the battery connector (a jumper from the JST on the 3-in-1 to the Align on the battery).
Stock 800 mAh battery, stock radio, no external gyro, stock motor and pinion, stock suckky tail (2 heat sinks), symm woodies, flying weight 312 grams.
