RCU Forums - View Single Post - What do you have your conversion in???
Old 01-05-2007 | 09:36 PM
  #92
hardtop351
Default RE: What do you have your conversion in???
ive noticed there is 2 switches on the same side as your ignition module. im wondering if one of them is for your radio gear and the other for your ignition system.
if this is the case then you will more than likely have the ignition cut through your radio gear. keep your radio gear as far away from ANYTHING related to your ignition system to avoid problems.
cheers
craig
