RCU Forums - View Single Post - Bobcat Question
Thread: Bobcat Question
Old 02-12-2002 | 12:34 AM
Gordon Mc
Default The rest of the JR list...
In addition to the servos (which I just checked and confirmed my previous post against the manual), here are the other JR parts called for:
4 x JRPA215 Heavy duty servo arms
8 x 24" servo extension leads (2 for ailerons, 4 for elevators, 2 for rudders)
2 x 12" servo extension leads (rudders)
4 x Y harness (1 aileron, 1 elevator, 1 rudder, 1 steering)
Of course, the y harnesses etc. assume that you want to Y the various extensions together. I didn't do that. Per Tony's excellent setup document (available from the BVM site), if you use separate channels for each aileron then you can set up flaperons; if you use seperate rudder vs steering then trimming the tracking on the ground independently of in the air is a breeze, etc.
I'd suggest that you read Tony's doc and assess your options before buying the extensions and Y's.
Gordon
