Ball diff for nitro rustler...
what does the ball diff replace when installed?
and i heard there are ball bearing you can use in the spur instead of the red pins... is this true? if so what would that help and where can i get them? or does the ball diff eliminate the need for that?
...cuz i think i partially melted my spur/red pins down a little bit by having the slipper to loose...
