RE: Ball diff for nitro rustler...
I think you may be confused. The ball diff is in the transmission case. They perform better than gear diffs and don't require much maintenance. I havent rebuilt mine yet. Just make sure it is at the right tension every so often. The little redd things are friction pegs. That is part of the slipper clutch. Just buy new pegs then read you manual on how to set it.
