RE: Nitromodels Tiger Moth Build along?
I first flew my Tiger Moth with out flying wires and just added them later for looks. The design of this model is strong enough to fly with out wires. They send you all the hardware you need to set up the wires. I have taken a whole differant approach. I was not sure how my radio would react with all that steel cable webed between the wings so I went down to walmart and got some 1/8 inch 50 or 60 lbs black nylon cord to use for the wires. I installed the nylon cord to the mounted secureing tabs included in the kit with small fishing swivel hooks. I cut the swivel part from the hooks and threaded the nylon cord through the hole then tied a single knot secureing it with CA glue. I did it this way so that I can easly remove the wires when I take the wings off. It seems to work out with no hassels.
My Camera is down for the moment, If want I'll post some pics if you think that will help. It would be no problem to post pics once I unload the pics already have on it.
Laterzzzzzzz
Dolan~wingman~Gallier
Polson R/C Avation Group
