RCU Forums - View Single Post - Composite ARF Impact - New Build for 2007
Old 01-06-2007 | 12:24 PM
Malcolm H's Avatar
Malcolm H
Default RE: Composite ARF Impact - New Build for 2007
JFetter (wish you would use your first name - its easier to be friendly!)
Installing the ladder is 10 minutes work. Use the supplied foam crutch as a tempate to fabricate the balsa one. Slide in the fuz and sand where necessary to get contact along its length.
Sand the inside of the fuz to remove any mould release agent (attach paper to balsa sticks with doublesided foam pads to get compliance).
Coat the ladder with 20 min epoxy mixed with chopped cellulose fibres and slide in place - job done!
Malcolm
