RCU Forums - View Single Post - Official HPI MT2 Thread
Old 01-06-2007 | 03:15 PM
  #12013
Joebaby35's Avatar
Joebaby35
My Feedback: (14)
Default RE: Official HPI MT2 Thread
ORIGINAL: arapoda
Bare with me on this problem, but it's a continuation on my clutch bell saga that some of you are aware of.
Okay, so after buying a new clutch bell, attaching it and sorting out the mesh with the spur gear, I now face a new problem. Today I went to give the car a test run, so I pulled the pull start but the clutch bell gear locked up.
Now, a few days ago I realised that if the screw on the clutch bell is tightened too much, the clutch bell cannot spin. Because of this, I leave the screw slightly slack to allow it to spin. Today, much to my frustration, I found that as the clutch bell gear meshes with the spur gear (and when the pull start is tugged) that the screw tightens itself into the thread (thus locking up the gear). I'm baffled as to how to find a way around this?
I've got thread lock, but surely this must only work for screws that are tightly threaded and not slack screws?
Here's a picture of the afore mentioned gear and the problem screw in question:
Any suggestions folks?
I'll be offline for a few hours, but I'll check back later.
Get rid of the washer that is your problem. That washer is for the original CB with the needle bearings. When you tighten the screw it pressures the washer up against the CB causing it to lock it in place. Also it is very important to put blue thread lock on the screw holding in the CB. You should be able to tighten that screw all the way in and the CB should be able to spin freely. If it does not!!! remove the washer on the inside of the CB as well. Those washers are very thick, what you need are shims to space the CB properly not washers. Get the Ofna CB kit listed below.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJKN3&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXNXK4&P=7
