ORIGINAL: Hughes500E
I flew the 1/6th Waco with an Enya 60 4 stroke and it was excellent. If I were to build a 1/6th, you could be guaranteed a Saito 72 or 82 would be on the nose!
_____________________________
WACO Brotherhood #2
ORIGINAL: Stickbuilder
Yep, thought so. Saito offers the 60 twin for $549.99 which is an ABC engine with muffler. They offer the 90 twin for $599.99 which is the AAc engine (no muffler mentioned), and get this... the 100 twin is just $499.99 and this one is an ABC engine with muffler.
The max width on the 60 is 160mm. The length from mount to prop hub is 125 mm.
The max width on the 90 is 170mm. The length from mount to prop hub is 120 mm.
The max width on the 100 is 169mm. The length from mount to prop hub is 100 mm.
These numbers are directly from the Saito twin cylinder manual, and the prices are direct from Horizon's web site. You can download the manual by doing a Google search and typing in: Saito model airplane engines, and selecting the Horizon site, and specifying Saito engines. I just did it.
It looks as if the 100 twin would be perfect for the 60 size Pica Waco. The width is about 6 1/2"
Bill, AMA 4720
WACO Brotherhood #1
THANKS GUYS!! [sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
One of those Saitos will more than likely be the power for my Waco.
If I'm measuring the inside diameter of the cowl correctly, I've got to keep it within 6 3/8" to stay inside it without cutting it up.
I'm going to Horizens site and check out the twins, and the 72 and 82.
Many Thanks! [sm=teeth_smile.gif]
NI
WACO Brotherhood #16
