RCU Forums - View Single Post - PLease help meee!!!
Old 01-06-2007 | 08:30 PM
zack221
Default RE: PLease help meee!!!
You might have an air leak and it is causing it to run really lean i would take the motor out and pull the fuel line off the gas tank then leave the other end attached to the carb nipple and blow through the line if you hear air than you have a air leak try to find where its coming out and seal it up with high temp silicone
