Bill, the stock motor (Goldfire) is just a plain 550/600 class motor, nothing special about it. It has plain bronze bushings and small brushes. You can putt around just fine with this motor.
Batteries have come a long way in the 5 years since you've had your e-streak. You can have longer duration AND greater performance.
A cheap upgrade motor would be a Kyosho Atomic Force 17T. This is a fully timing adjustable motor with very large brushes and ball bearings for about $20. It lighter than the stock motor and will bolt right in. Runs great on 6 or 7 cell packs. You will need a higher current ESC than the one that comes with the e-streak ARF kit though.
I used to fly mine with a CEM FAI15 motor on 8 2400 cells. Fast and good long duration (8 minutes typical). If you want to go slower and stretch the duration that's what the throttle is for
For the best of all worlds, a quality brushless motor will extend flight time and give higher performance at the same time.
