RE: PLease help meee!!!
Hey nitrospeed33 i just went out side to start my volcano after about 2weeks of not driving it or even starting it and mine was doing the same thing.The first thing i did after it died was turn the flywheel to check for compression and it didnt have much and then i saw the glow plug was loose so i tightened it up and i had compression.It fired up but was still doing the same thing so i screwed the hsn all the way in and backed it out 2 1/2 turns.Then it was still hesitating so i leaned it out a little more about 1/4 a turn and it went away.Then i did the pinch test and it raised a little before it shut off so i left it that way because it is supposed to be a little colder tom. and it should be pretty close on tuning tom. now i just gotta fix the idle on it.It idles fine but soon as i tap the brakes it dies but i will fix that tom.
