RE: SuperTigre mid-range problems?
hi down under
this is a new set up everything is like it should be i did make the out let tubes smaller it helped some but i still can't get it to run really rich i backed out the idle bar didn't help other than messed up the idle it should run by intake suction only but no matter what nothing changes it goes the same with or without the pressure tap i had a idle before at 1190 1205 rpm and very stable i thing i will have to go with a perry pump any ideas
bob
