RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 01-07-2007 | 03:10 PM
  #853
choppersrule
Default RE: E-FLITE BLADE CP PRO
Justin,
I had the same problem a few weeks ago, thought the battery was going dead. It wasn't the battery, the motor was going bad.. Replaced motor, now everything back to normal.. If you motor is real hot after another run at it, you motor is probably shot.
Before doing that, make sure that your gear mesh isn't to tight, that can put an extra load on the motor also. Just spin the blade by hand, it should move easy and free of any binding. You shouldn't hear any grinding at all.
Dave / Choppersrule
ORIGINAL: Commander_Bob
I just lubed it up real nice and did Jellyson's pitch and throttle curves and it got off the ground and to around 10-12 ft for about a min and then it came down. It acts like it does when a battry is dieing and needs to be chareged but more sever. My battries cheack out on the volt meter though...
Help me [:@][&o]
Justin
