RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 01-07-2007 | 04:51 PM
  #858
chopperdudes
Default RE: E-FLITE BLADE CP PRO
justin, yep, you might better try another motor first, especially if it goes hot on spoolups.
Copperdudes
(and anyone else who can help),
how did you move out of hover into FF. I have heard of slow ff to one side the a half piro and back and forth progressing farther, faster and wider until your fly big fig 8's....alternatively I have heard to fly in a circle around yourself in one direction and then the other before doing fig 8's....I have flow pretty far and fast forward and backwards away and twords myself, but i am nervious about incorporating turns into FF. How did all of you start out with FF...any advice would be gfreatly appriciated.
i started ff by flying circles around myself, more or less tail in at first, then turn the tail to follow the nose. then i actually started turning by doing a semi-stall turn. it'll fly from left to right in front of me (master side in first), then pull up to about 30~45 degree, and swing the tail around, no collective change, no aileron control, much easier, since a turn needs all 4 controls.
