RCU Forums - View Single Post - Composite ARF Impact - New Build for 2007
Old 01-07-2007 | 08:15 PM
jfetter
Default RE: Composite ARF Impact - New Build for 2007
ORIGINAL: PeterP
Aeropoxy otherwise known as Hysol $$$$ works very well but I would limit its use to high stress areas because it is heavier than epoxy mixed with microballons.
I posted a lot of material in the other IMPACT forums regarding build and alignment. I would suggest you look through those. I dont really have the time to go through that again.
I am still flying my IMPACT almost 1.5 years later with YSDZ160 power and it is holding up well.
I have started to build another IMPACT because the kit was going cheap. I will be making a few mods to this one after my experience with the first.
The model does fly very well. Dont take the alignment settings already marked on the fuse as they are a fair way out.
Peter
If you had to list the top things you'd change the second time around (which you in-fact are doing), what would they be? Yes, I did read the other forums, pretty detailed and gathered a lot of great info in there, I just didn't want to startup again in there for fear no one would check back that might have been an original contributor. I am concerned about the alignment comment, my experience with incidence and aligning wings, stabs is well, nil, I have never had to do it and simply relied of manufacturer settings or markings. Is this tough to do?
Thanks for the tips!
Jack
