RE: need help with CPP problem
you might try testing the stock gyro to see if your alien gyro is causing problems. if it still flies funny, you may have too much pitch.
as a last resort, you may want to upgrade the tail. many ppl who have a brushless main motor also have either direct drive or dual motor tails to help cope with the rotor-torque a brushless main motor can produce.
don't give up yet. if all else fails go back to the stock setup and have fun flying it for a while.
