RE: Substitute for Ether
Friends,
now the discussion is opening a new front, but to be clear a mix is a mix and every components ha to match the others. Combustible, lube and improver ( today I suggest to include ether in this cathegory) must match somewhat each other. The blanket is short, so. every component is affected by others. Discussion as fairly open.
I propose to use a template as below for discussing and possibly compare mix proposals and references. This thread is so long that something useful can be lost or inadvertidely repeated if not properly resumed. Reference over wich to discuss may be useful both to participants and viewerrs. I hope you will adhere by filling the form with the mixes you have already formulated and/or tested.
Suggested mix report scheme
MIX NUMBER: SUGGESTED NAME:: DATE:
ORIGINAL REPORTER: LAST EDITOR: LAST EDIT:
OTHER USERS:
FORMULA (in order of decreasing percentage of volume ):
1) %
2) %
3) %
4) %
The way the mix it was obtained:
1)ENGINE: CARBURETOR: RUN TIME: STARTING: USER:
Comments:
2)ENGINE: CARBURETOR: RUN TIME: STARTING: USER:
Comments:
Additional user obsevations:
Nickname : Observation:
Non user comments:
Nickname : Comment:
Nickname : Comment:
PURPOSE:
SHARE FORMULAS, EXPERIENCES AND SUGGESTIONS.
RULES:
EVERYONE CAN ADD HIS EXPERIENCE AND/OR BRIEF COMMENT FOR A GIVEN FORMULA by reediting and setting edition date
USE:
COPY; EDIT AND PUBLISH. NO CONTRIBUTION CAN BE MODIFIED IF NOT BY ITS AUTHOR
END
Who wants to start wth the mix No 01 ? Thanks
Ugo
