RCU Forums - View Single Post - RTF Firewall problem
Old 01-08-2007 | 08:18 AM
Carpilot
Default RE: RTF Firewall problem
The Firewall points to the right correct? this is normal the ponting to the right is to offset the engine torque. If it was mounted perfectly straight the plane would want to pull left constantly.
Also it's a trainer, if you look closely you will probably see that the engine is angled down a little bit also (compare it to the angle of the wing)
