RE: spot welding and simulators.
David,
Those metals are hard to solder or spot weld. You have to use argon gaz to solder them, otherwise they would oxidate in time.
If your parts are small, I could do it for you. You can check what I did in the Savex L39 thread for my thrust pipe.
Spot welding is not as strong. If you want to make you own device, you need a powerful transformer.
For the simulator, give me youe address, I'll send you a copy of aerofly. Mine is already a copy of a copy of a copy...
Yann
