RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 01-08-2007 | 03:37 PM
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: Wheeeeeeee.......... Blade CP!
Oh cripes crash.......... At least you had parts on hand.....and didn't have to go to LHS.....and buy more than what ya need. I always walk out of there.......limping, torn, bleeding, and broke.......lol.
I have noticed my tail boom was epoxied back on. Not from anything I have done....but was that way when i bought it. Got mine to hover last nite for a few seconds....then TX was shutting off...........luckily the 4 in 1 kept disarming when TX lost power. Turns out.....don't buy AA's from a the dollar store! They are smaller diameter and slop around inside TX case. Losing contact at critical times is not a good thing. Have some other batteries that should work luckily........am balancing the blades right now. Will also lube the bearings on main shaft since i already have most of the stuff out of the way. I noticed a wobble in the top if the main shaft while powering up last nite. So am trying to get that fixed.and also adjusted servo links again. still getting a lil forward left slide on power up.
Found the cables for hooking up camcorder to puter...so will try to get some video of my antics. I can't let ya one up me on photos and video too. I looked for your video...but didn't see it. I am assuming you haven't posted it up yet. If ya got it uploaded somewhere....how about a link.....i want to see how yers hovers and whatnot......see if mine is even close to adjusted right.
__________________________________________________ _______________________
Of all the things I ever lost........................ I miss my mind the most!
