Hey check this out>> I went to my local Hobby Town and found a nice prop on the wall(plastic with molded on nose cone), took it to the fella behind the desk and asked him if it was a puller or a pusher. He said" depends on which way the propeller is turning">LOL. After about 5 minutes of listening to this nut, I finally asked him what plane does this go on>> He pointed to a plane hanging from the ceiling and it had a PUSHER set-up>lol Scarry!!!!!!!!!!, Scott[X(]
ORIGINAL: fliprob17
1. I believe it should rotate clockwise if you are looking from the tail of the plane towards the nose. It is a pusher prop.
3. You could manufacture some kind of a mount or sleeve. The easiest install is to foam safe CA it in there.
