RCU Forums - View Single Post - Motor mount angle
Old 01-09-2007 | 03:25 AM
KingCobra2's Avatar
KingCobra2
Default RE: Motor mount angle
Your motor , I believe, should be parrallel with the fuse or with you wing if I am not mistaken. YOUR motor is not mounted correctly!! That looked pretty sadYou might try another prop(after aligning motor) that is 1 inch longer or maybe 1 1/2" longer. you might want to add another battery or two also to try to retain your motors powerband. With your motor pointing down> It will seem like your plane is nose heavy BUT the prop is just pulling the front of your plane down!! Please try parrallel with Fuseor tail wing.ALSO, you might try a 400 motor. take care, Scott
te]ORIGINAL: allant
Well, I finally got my C17-E Biplane in the air, after about 4 crashes where I re-glued a wing back together, re-glued the 380 moter back in after it popped out (nose dive), and removed landing gear as it busted off 2 times anyway.... I wish I would have started with an easier plane.. I do get good hand thro take-offs now, but at full throttel, I can't seem to get mush altitude (Even with a little up rudder), and easing into turns with slight rudder and slight up elevator, I havn't had enough altitude to keep from crashing... I'm not sure how much more punishment my C17-E Air Wecker plane will take!!!
Does anyone think that a larger prop on this 380 would help give me any more speed, or do I need to go to a larger motor, or just give up with this plane and go for a more common trainer plane?
[/quote]
